Hey guys,
So I'm in a bit of a pickle right now. For my DIY go-kart I decided to pick up a single hydraulic brake setup. The go-kart already had an 8-in brake rotor that's 3mm in thickness.
I went through Go powered sports to pick up the new brake system and it came with a master cylinder and brake caliper with brake pads installed.
My first question is how I'm supposed to properly install the master cylinder? This setup came with no instructions and the research I found online have all had various other kinds of master cylinders not exactly like this one.
I'm assuming the two holes in the picture are where I would maybe mount this on the go-kart frame?
But this little gold metal piece is also confusing as it looks like it also attaches to those two metal holes. Am I somehow supposed to attach that to my brake pedal or brake rod? Not sure how that's supposed to work if it's also mounting to the frame.
One other issue I'm having is with the brake caliper. They seem to be brushing up against the rotor even when not engaged. Is it possible the rotor at 3 mm is just too thick?
I'm just having trouble finding good resources on how to properly install this so I'm at a loss at the moment. Any guidance you guys could provide would be really helpful.
