Trying to describe "performance driving" in a sentence or two probably isn't going to work out well. You're going to have to practice. What I can suggest is brake early (before the entry to the turn). If you lock the brakes, the rearend's gonna kick out on you, so you need to practise threshold braking. Basically, it's just on the "threshold" of locking up, but not quite. You want to get off the brakes before actually entering the turn, or the weight bias will be too far forward. Now, you can either coast or gently throttle thru the turn, then start getting into the throttle as you're coming out or...
After entering the turn, drop the hammer (floor it). The rearend will kick out (assuming sufficient power and live axle) and countersteer your way thru it. This is what we call fun.
If you're new at this, it will take some practice. Timing is important, and you need to get a feel for your brakes and throttle, weight biasing, traction, etc. Besides- practising this stuff is FUN!
