Tyrod IV Go Kart
rpolanco
West Sacramento, CA
Anyone know where to get parts for a Tyrod 4 Go Kart? I need wheels because the old wheels cracked into 4 pieces, and the hub pattern is really weird. It's 3 holes on about 2 3/8 in pattern.
950speed
Texas
Should be able to just buy new tires, or do you mean the wheel itself cracked?
950speed
Texas
Can we get a picture of the cracked wheel? And from then on it would probably be a good idea to find what caused it to break like that. It seems really odd
Did you hit a pot hole?
Drop it somehow?
Most likely it came from some sort of impact which was more than the wheel to handle.
And was it the wheels the kart cams with or did you replace them yourself.
Pics would help!!!
you sure?
3 on 58mm is std bore holes for european race karts... (smaller one of the two.. 68mm is also a thing)
that's close to 2 3/8" but not quite.
post a pic of your hub and measure bolt to bolt
I'll compare it to my hub bolt to bolt and we'll see how close we got ;)
