Two Engine Questions.
B.M.800
TheBeal.
Central PA
OK, I dont know much about engines, so these questions mught seem stupid, bear with me here...
So, I was wondering how much "mods" a Honda 6.5 could take. Not just removing the govenor and valve springs, but this. What would I expect from doing that. I dont plan on doing that anytime soon, but Id like to know just in case.
The other question, We have a seized up B&S 5HP. Is it possible to get it running again? Rebuilding?
Thankyou kindly!
freakboy
the names 'mater
hick town
that seized up 5 horse is definatly rebuildable... and you can do alot of mods to these things... most of them are simple as all hell...
B.M.800
TheBeal.
Central PA
Russ, what language are you speaking? I have almost no idea about what your talking about... kool bore? What might that be?
How long of a life would I expect from a Honda 6.5hp with most if not all the modification in the link? About how much hp, how many rpms?
Thanks.
Bluethunder3320
now just making sure, is it a real honda or the more popular clone?
clone will last 10 times a shorter life than the clone.
as for the briggs take it all apart in a place you wont loose parts and take a pic of inside the engine/the cyl.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
A sleeve bore is a cast iron sleeve, pressed into the block and a kool bore is just a machined part of the aluminum block, correct Russ?
B.M.800
TheBeal.
Central PA
Yes, a real genuine Honda. :)
English...but never mind, I was just trying to help.
Sorry, I wasnt trying to sound rude, I just have no idea about a kool bore.
sideways
Unfinished projects king.
Perth, Western Australia
How would I go about getting the piston loose?
Take the spark plug out and pour some diesel down there, just 10ml or so. Wait a few days then put a breaker bar on the flywheel nut or PTO bolt and see if you can make make it turn over, don't force it too hard, especially if it's on the flywheel nut. Your might not even have a flywheel not depending on what kind of starter it has. It will pay to take the head off and see what the bore is like, If it's just seized from sitting then you should be able to get it going again, if it ran out of oil or over heated then it's probably stuffed. Take the side cover off to and see what it's like, check the bearing surfaces. While your there (and if you think you can get it going) you may as well reseat the valves, you could also do some porting and relieving and remove the governor if you want to.
Thanks
Hayden
B.M.800
TheBeal.
Central PA
I think it musta seized from sitting, it was burried in a shed. It still has some oil in it. I already took the head off, bunch of crap on the piston, and on/around the valves. Is there anything else that I could put on it? Would parts cleaner liquid work?
Thanks.
Oh, and its pull start.
sideways
Thanks.
That's good news. What was the stuff on the piston? Just carbon? Just use diesel, it's cheap and has brilliant penetrating qualities.
There's different pull starters which will dictate whether you will have a usable flywheel nut. Yours probably has the ball free wheel one, which means it wont have an accessible fly wheel nut.
Good luck with it mate. :thumbsup:
Thanks
Hayden
B.M.800
TheBeal.
Central PA
Should I try to get the crap off the piston and valves?
How do you suppose I get it to turn over? Maybe put a bolt or something in the shaft?
#1- Couldn't hurt
#2- Personally, I'd just go ahead and disassemble, instead of trying to find new and creative ways to force it over. Get everything else apart including the crankshaft, then let the block sit for a day or two with the diesel or whatever in the cylinder. Then, carefully and gently start tapping the piston out. GENTLY.
Once it's out, hone the wee out of the cylinder and clean everything up nicely and proceed with rebuild.
robbie
Osceola, Missouri
Kerosene and diesel are basically the same thing. I'll agree with Russ about the transmission fluid. It is formulated to remove crud.
The best tool to tap out a piston is a piece of wood and a big hammer. Use a large piece of wood, small enough to fit into the cylinder, but big enough to spread the force around the piston.
