Turning Two into One
Tony
Dafter Michigan
Hey i have a 2 cylinder yahmaha 340 snowmobile engine. I need to turn it into a single cylinder. Do you guys think it its possible?
Tony
Dafter Michigan
vintage snowmobile races. It has to be one cylinder. I also wanted to install dual plugs in the head which would be easier to do with a 2cylinder.
Kaptain Krunch
Pro Junk Collector
vermont
I would take the mag side cylinder, con rod, and piston out, and make a cover for it, personally i would get a single cylinder engine and use a twin coil...
Tony
Dafter Michigan
I have a single (292 sachs) but it needs a head and im building on a budget. The yahmaha was free so i thought why not.
solomon
ca
sounds like you will need to play a little with the timing though.
Kaptain Krunch
Pro Junk Collector
vermont
And why is that?
I guess if it was free go for it... The only problem i see if the crank bearings in the cylinder u take off will be in trouble, if you filled it with oil the crank would probably just churn the oil.
solomon
ca
I would imagine the timing would be off due to the motor running on 1 cylinder instead of the 2 cylinders it was timed for, but i guess if tier was no piston in that cylinder i would be fine. IDK i just figured the timing would be off, by doing that to an engine
Kaptain Krunch
Pro Junk Collector
vermont
Shouldnt be, both should fire every revolution regardless, at least most do.
Tony
Dafter Michigan
the timing wouldnt be off unless i did the 2 plugs in one head. But i just realised that one cylinder of a 340 is 170. That isnt engought so its back to my sachs.
