tuff toro gearbox
ML-TOYS
long island, new york
tuff torq gearbox
so i was given this today, are they of any use on a kart ?
this one has a built in clutch and 3/4 keyed axles. if i was to use it i would stand it up and run the input shaft horizontal.
what does ths mean about the gears
Transmission: Tuff Torq K51A
Type: hydrostatic
Gears: infinite forward and reverse
It's not a gearbox, it's a hydrostatic drive. Not very useful on a kart. If you try to spin it too fast, the hydraulic pressure can get too high and -poof!-
for ultralow speed (lawnmower speed) for kids, it is a great choice. You'd connect ONE pedal or stick that goes back and forth. The further you push, the faster it goes. No clutching or shifting- ever.
DaiSan76
Nixa, MO
I wonder if you could put a sprocket on the end of those axles and run like a 1:5 ratio or so. Those Hydrostatic drives have gobs of torque.
trikeman
Ireland
I tried using a similar hydraulic drive and it drained alot of power out of the engine just to make it turn.
But with a non-speed (maybe dirt) kart, and as daisan76 said a 1:5 final drive then it would be very torquey.
