troubleshooting predator
connmania@gmail.com
I recently tuned my predator 6.5hp engine (old style) I did the following modifications to it:
max flow air filter
20lb springs
new carb jet
removed governor
racing spark plug
I believe that all of these mods went flawlessly, but i might be wrong being that I am somewhat inexperienced on the subject.
anyways, after doing these mods I put fresh oil and gas in and tried to start. immediately, i realized that the compression had changed drastically, and it was much more difficult to pull then stock(i imagine this was due to the stings) so after 2 pulls the engine completely locked up and i couldn't pull,i pulled a little harder and and i was able to get past the "kink" after continuously muscling it i realized that after 3 or 4 pulls the engine becomes extremely hard to pull(so much i can't to pull it)
this seems like an odd scenario and haven't seen/heard anyone online with the same issue. It would be much appreciated if anyone can give me even a little bit of advice.
Hello and welcome
Why did you choose those springs?
and typically if one rejets and new air filter, they also get a free flow exhaust aswell.
Heavy valve springs are at the bottom of the mods list, after the billet conrod & flywheel...
Can we assume you didn't open the engine case?
It's possible a pushrod has been dislodged, preventing a valve from opening or, worse, preventing it from closing...
connmania@gmail.com
thanks for all of advice!
so what im gathering is I should check alignment like anderkart recommended.
also do you guys think I should take the springs back out and replace stock?
and just so I can clearify the engine isn't completely locked up it just is difficult at some points and very difficult at sporadic points in the cycle while pulling(wont start at all). in my opinion this rules out any suspicion their are parts lodged in the engine or pushrod dislodged.
also, gran_pann - what is compression release?
Half-breeder
"Edit" button removed
Put the stock springs back definately
:iagree:... make sure to adjust the valves proper gapping, or she still wont start. IMO/my guess... the restrictive pulling of the cord could possibly the valves being gapped wrong(seeing as that OP had said it still pulls... just hard at different intervals).
Scout
Nutjob
Indiana
Compression release is a lever on the cam that releases some compression when you pull the cord. makes it easier to start. It's inside the engine and nothing you have control of.
connmania@gmail.com
okay so I put the stock springs back in and I noticed no difference. still not starting. im starting to question whether my gapping is correct like scout mentioned. I gap it perfectly and then pull it a few rotations to make sure and gapping is completely off. how do I fix this?
thanks again for all the advice
