Hi Guys,
I'm a new member from Ocala, FL who is attempting to mount a Comet TAV2 on a 212 Predator for use on a rusty old yerf-dog that I am trying to bring back to life. I tried "Search" but was unable to find anything similar.
-I have the mounting plate tight against the crankcase
-the supplied spacer is on the crankshaft
-with the "flat side" of the driver on the shaft in front of the spacer, the driver is located at least 3/16" too far in toward the crankcase to line up with the driven.
- I can't shim the driver out anymore because the shaft is so short on the Predator that only about 1/2'' of shaft is now available to catch the splines on the driver.
- the driven is factory installed and has no adjustment
- should I just ship the Comet TAV20 back to the dealer and try another brand of T/C. Go Karts USA has a GTC T/C that they claim will "bolt right on" to a Predator. Have any of you tried those?
-Does the short crankshaft on the Predator create a problem with the mounting of any T/C? Will these drivers operate OK if the splines are only able to catch about 1/2" on the end of a Predator shaft?
I appreciate everyone's help and suggestions. Thank You!
