Nodroz
Hello,
I've just bought this motorcycle engine that came of a dirt bike from xmotos.com, it's a 200cc 5-speed engine.
When I came home I noticed there wasn't a spark plug cable.
Does anybody of you guys know something about these engines? Will I need a ignition coil?
I want to test the starter. Can I just hook up a 12V battery, 50amps, directly to the starter for a few seconds?
Meanwhile, I'm trying to find a electric circuit for this type of engine.
PS. I already opened the flywheel case to see if all that stuff was intact. The inside looks really good. No damaged or worn out parts are visible.
EDIT: I found the serial number: 163FML (it's in the pictures too). It appears to be a lifan engine? Could somebody confirm this?
EDIT EDIT: Just found this interesting topic: http://www.dirtbikeaddicts.com/threads/sneeze-163fml-chinazaki.1992/
After a bit of googling I found this: http://www.amazon.com/Ignition-Stro.../ref=cm_cr_pr_product_top/192-1772095-3581768
Is that what I need to get it running?
Regards,
Nodroz
Regards,
Nodroz
