trailmaster 150xrs not starting
MDNUSA
Hello everyone. My sons Trailmaster 150xrs has started acting up. The starter will spin but the motor will not. Sometimes there is a grinding noise. After quite a bit of cranking it will catch and the motor will spin and start and run perfect. I have replaced the starter with no change in behavior. Also, when I stuck my finger in the hole for the starter I can move the “flywheel” back and forth. I have a perfect video of it acting up but I do not know how to post it. Any help would be much appreciated. Thanks and have a great day.
Brianator
Gettin' er done!
Barrie, Ontario, Canada
Back and forth as in side to side or fowards/backwards I relation to engine rotation? How much play is present?
Post it to YouTube and then add the link here.
Snaker
Sounds like the starter clutch is boingo. Go to American Land Master, service manual for 200 series.
Brianator
Gettin' er done!
:iagree: with Snaker based on the video and parts diagram. What I wonder if this bearing (circled) is a one way bearing or not? I haven't been into one of those engines as of yet...
MDNUSA
Thanks for the help guys, that video helps a ton! I'll be ordering the cover gasket and starter clutch this afternoon. Thanks again!!
