FlyFrog
the 97 craftsman ic golds are really common and they have a simalar hood to thatView attachment 130300 im looking for this style hood and dashto swap onto my newer chassis
it looks lifted did you lift it?i have the same exact mower with yellow rims and a red and white paint job
edit: and yes it has a hood scoop...
Budgets Tractor Builds - Page 2
i paid 100$ for a simplicty broadmoor hydrostatic with a 16hp vanguard vtwin because it overrevved and the transmission was being over driven causing it to notwww.atltf.com
did you just put body lift or spacer the axles and such to lift it (if you can add pictures on how you did it)the red one is stretched and lifted i think about an inch, the gt is lifted quite a bit
lmao we both in class and on here, i think im going to have to do this, id like that little bit more clearencei have all my pics in the thread on ATLTF.com here i made this diagram. alsoi had to weld a peice of rod and a ball joint on the drag link View attachment 130307
those plates are mounted with just the top bolt on each side the back plate is bolted lower leaning the axle back a small bit giving it caster
The orange one is such a cutie. Looks pretty much string too.Ok, ill bite.
First is my 1978 kubota b7100, 3 cyl diesel. Works harder than i expected...but still not big enough. Lifts about 800lbs with 600lbs of counter weight on rear...already rebuilt the steering box once
Next is the 1977 john deere 300. My dad bought it shortly after i was born. It went through a flood in 2011, sat till 2017, and ive slowely been restoring it. The frame, axles, and steering column are orig. I rebuilt the transmission. The body panels and engine are from a 314 doner.
Last is a 1968 ford lt120, with a 2011 briggs 18hp v twin....on its second tranny, does wheelies for days, and about 25mph in 3rd.
Sent from my SM-G892A using Tapatalk
