Tractor gearbox smart guys
ML-TOYS
long island, new york
I have a craftsman with the 6 speed forward. It has the shifter in the center between your legs.
When its not running i can go thru the gears easily. When running it stays stuck in gear with brake applied unless i rock forward and back.
Not sure if its a coincidence but i just replaced the drive belt but dont see how that would cause this.
Any ideas guys ?
with "running" you mean the engine is running
not the vehicle is moving, correct?
If so, IIRC there's a belt tensioner that's been disengaged by the brake
(which basically acts as a belt clutch)
Peek under it and see if that's still working properly or not,
might be as minor as a wrong routed belt or a missing spring.
With unsynchronised gears you can't shift (nicely) when the input shaft is turning of course..
Maybe a pic could help (you know.. belt and such ;))
I had a similar issue with my riding mower with a FNR transaxle; turned out to be a maladjusted belt guide...
All I'm saying is it's probably something seemingly insignificant; double check everything you touched during the belt change...
ML-TOYS
Ok thanks, will check again over weekend. Might try putting old belt againand see if that actually made a difference.
While i have it floaing in the air i will try some pics.
Thanks again.
Joe-405
Enjoying New Projects
U.S.A.
the belt is too tight. It wont shift cause the belt is got pressure on it and its spinning still.
I bet you can be driving at a steady rpm and hit neutral huh ? Kinda like shifting with no clutch in a car. I am a small engine mechanic and work at a lawn mower shop for a living. This is the only thing it can be unless the trans is broke internally which they ususally dont do or a pulley has bad bearings in it.
