Torque is in Lb-Ft.
Tire diameter is in feet.
Gear Ratio is a multiplier.
If you have 10 Lb-Ft of Torque...
And if you have a 6 :1 Gear ratio...
You have 60 Lb-Ft or Torque at the axle.
If you have 12" Tires, then the radius is 0.5 Ft.
Divide Torque at the axle (in Lb-Ft) by the radius of the tire (in ft) to get a linear force.
60 Lb-Ft / 0.5 Ft =
120 lbs of linear force.
Torque spins stuff. Linear force pushes things forward.
If you haven't heard me say this before...
F=ma
(good for at least 1pt partial credit on every Physics homework, quiz or test on the planet)
Linear Force = mass x acceleration
If you want to increase acceleration, you have to decrease mass or increase the force.
To increase the force you need more torque, a shorter gear ratio (bigger number), or smaller tires.
10 Lb-Ft at the crankshaft, 6:1 Gear Ratio, 12" Tires... Equals 120 lbs of force pushing the vehicle forward. Smaller Tires means the same torque yields more linear force. Bigger Tires with the same torque will yield less linear force.
As RPMs increase, tq will generally fall off. So when an engine gives max TQ specs, it will usually be at like 2500 RPM. Highly modified engines might make peak torque at a higher RPM like 4000 RPM.
---------- Post added at 12:58 AM ---------- Previous post was at 12:44 AM ----------
PS in 'Merica we don't use newton meters. I'm not on a diet. Ain't nobody counting my cookies. LOL
---------- Post added at 01:16 AM ---------- Previous post was at 12:58 AM ----------
Any non-zero torque can adequately move any amount of weight when time and distance are omitted. We don't have enough information to answer the question.
I agree if you say time, distance and FRICTION are omitted.
Since you did say move, we can assume distance is greater than zero.
But, the force has to be enough to overcome Static Friction to begin moving and the force has to be equal to the kinetic friction to keep it moving at a constant speed. Force has to be greater than the kinetic friction to accelerate the mass.
So if you consider friction, I have to disagree about "any non-zero torque can adequately move any amount of weight".
Unless, of course, you mean any amount of TQ output, before the gearing reduction. You can always use gearing to increase force.
