jslider
OK SO I BOUGHT THE CHEAPY TORQUE CONVERTOR ON EBAY FOR A 110.00, INSTALLING IT ONTO A PREDATOR AND I HAVE READ THAT SOME SPACERS ARE NEEDED DUE TO THE DESIGN OF THE PREDATOR 6.5 BUT I ENDED UP NEEDING ABOUT 3/4 TO 1" OF WASHERS STACKED UP TO MAKE THE PULLEYS LINE UP.
I KNOW THIS THREAD IS WORTHLESS WITH OUT THE PICTURES AND WILL GET SOME TONIGHT.
THE TORQUE CONVERTOR HAS THE BELT WITH ONE SIDE THAT IS FLAT OR A VERY SLIGHT ANGLE AND THE OTHER THAT IS A LARGER ANGLE.
JUST WONDERING IF ANY OTHERS HAVE HAD THIS ISSUE IN INSTALLING A TORQUE CONVERTOR. IT ALL BOLTS UP TIGHT BUT THERE IS PROBABLY ONLY 1/2 TO 3/4 OF AN INCH OF SHAFT ON THE DRIVER PULLEY PORTION THAT EXPANDS INWARD.
LIKE I SAID I WILL GRAB SOME PICS AND POST THOSE A LITTLE LATER.
THANKS FOR INPUT.
THANKS FOR INPUT.
he said "wingding"......
