Doesn't that sound to y'all like a belt getting cinched up in the driven pulley?
No
I have a torque converter on my mini bike that has a predator 212 and the problem I’m having is when I go full throttle and rip it a couple times the torque converter seems to lock up the bike will die and when I go to pull the string again the wheel goes with the piston so every time I pull the string it goes forward also the bike does not roll back only sometimes if I keep jerking it forward and backward then sometimes I can get the torque converter to come unstuck and the bike will start again and drive fine till the problem repeats I took the torque converter apart and everything seems to be in working order it is a little dirty so I am going to clean it any suggestions to fix my problem I would appreciate
Mine did something similar to this after several months... you need to clean everything out and relubricate it.
You are supposed to disassemble, clean, inspect for wear, and relubricate the driver every so many hours running. There's heat and friction regardless of lubrication type and amount, which means material gets shed from moving parts and gum it up.
Eventually if not cleaned the driver will begin to bind on the congealed slurry of metal and graphite.
On a side note, supposedly youre only supposed to use Comet dry lube or a graphite based compound. I've never been to find the specific paste, just the powder for locksets, so I've just been using PB Blaster white lithium with better than expected results for a bit over 3 years.
