torque converter spring replacement
zacmac1003
im replacing the spring in my torque converter and basically have no idea of what im doing. i know how the thing comes apart and goes back together my question is does the spring have any preload thats supposed to be on it or anything or do i just stick the tabs in the holes and tighten everything back down? btw i have never worked on a motor with a torque converter before so bare with me :mad2:
zacmac1003
i dont know what series it is but heres a pic, im relacing the spring in what i believe is the driven clutch, the one that drives the chain and axle, the one towards the right in the picture
zacmac1003
yea the old one broke, so what im asking is how do i put it back correctly to prevent another spring failure
Been a long dang time since I tore into one. IIRC, you put the spring in the hole, and turn it about a third of a turn so that when you bolt the two halves together, the preload holds the cam against the buttons. Make sure the buttons are in good condition.
zacmac1003
well here is what it looked like assembled new problem now, one part of the driven clutch is spinning faster then the other part and nearly destroyed this spring like the last one, anybody know what im talking about or seen this problem?
zacmac1003
it was running for quite a while without those buttons why fail now? btw im not sure if they were on there when we bought it either way its my little brothers kart my dad is ready to just buy a new driven clutch
zacmac1003
oh i believe you lol, just trying to troubleshoot this whole thing, first time dealing with a torque converter here, like i said may wind up replacing the entire driven clutch
Gwiz89
Port Arthur, Texas
Pulleys
Is it possible to replace the engine clutch (torque converter) with a max torque Go kart belt drive clutch for 3/4 bore A/B sect belt???? Thanks
