Torque Converter Questions
cswlightning
I'm looking for parts to build a go kart and I pretty much have everything. I found a good deal for an engine so I want to use some of the $200 I saved for upgrades. I was thinking a torque converter. Do they increase your top speed on flat pavement or beef up your acceleration? please let me know.
P.S. If thats a yes, what does the converter replace? the clutch, certainly, but anything else?
P.s.s Can you just use a normal 60 tooth sprocket and # 35 chain with a torque convertor?
toofarnorth
Wasilla, Alaska
A Torq-a-verter will increase your top speed 10%, but the real benefit is the improved acceleration, also for off road they are good for going low speed over rocks and up hills. Yes you would keep your axle sprocket, just make sure you get one set up for a #35 chain. The converter just replaces the clutch.
