Torque Converter Questions
For a higher engagement rpm you can change the stock zinc weights for lighter aluminum ones as well as putting stiffer garter springs ( the ones that go around the weights) in the driver. This will give you a stronger hole shot.The weights make a bigger difference than the springs. But between the two, you can custom tune to your liking. To keep the kart from shifting into high gear so soon ( this will give you more mid range power) you change the hole the spring is mounted in
in the driven. Stock is in the center hole. Move it to the left. Counter clockwise. You can also buy a stiffer spring for the driven. Dozens of videos on how to do this. Pay attention when you take it apart. Nothing terribly difficult.
OMB Warehouse sells everything you need. It is possible to really change how the kart performs ( with a ungoverned engine). As good as adding a a couple of horsepower in some cases.
