Torque Converter Question
Everett45
Idaho
I recently installed a regular old go cart torque converter on my 8hp B&S engine. I noticed from research that other torque converter kits come with a brass ring to put on the driver clutch, to prevent the belt from sitting there and rubbing while stopped. Mine did not come with one. My question is do I need one? Otherwise, like I said the belt will just rub on the bottom of the driver clutch at idle/stopped.
uhm.. what's that for an answer?!
No, if your TC didn't came with one (like no TC comes with one that's for a 1" shaft engine!)
you do not need it.
So since it's an 8hp engine it likely has a 1" shaft.. and you do not need NOR WANT one.. in fact installing a brass bushing would do more harm than good (and you had to make one ;))
sure you could install a series 40 on a 8hp engine...
but as you can see (or will be able to identify soon ;)) in OPs pic it's a series 30 TAV Kit!
