TORQUE converter question
Traviss1990
Ok, so i've exhausted several hours of research to no avail. Noone seems to be asking what i want to know. So, I'm building a kart and obviously i want the most power and speed for the least money. Long story short im considering a honda clone with and without a torque converter and a dirtbike engine. But, what i don't understand about torque converters is why they are rated as a certain horsepower level. Isn't it the torque that shreds belts? Consider a modded gx200 and a stock gx390. The 200 will have a little more than half the torque of the 390 but the same horsepower. Therefore couldn't you use say a 30 series TC with the modded gx200 even though it has 13 hp? Because the modded gx200 will only have slightly more torque even though the horsepower doubled.
CVT's are rated by horsepower with the following things in mind-
* Most people know the hp rating of their engine. When in doubt, it's usually labelled right on the engine. Torque is not.
* On industrial engines, PTO shaft size is generally ranged to hp. For example, MOST engines up to 8hp have a 3/4" shaft while larger engines tend to have a 1".
* None of these "ratings" whether it's the engines or the CVT's account for modifications. They refer to stock engines.
Traviss1990
ok, but that doesn't answer my question though. If I have a gx200 and all i do is take the governer off do i still need to upgrade my TC? If it's putting out the same torque (approximately) even tho the horsepower increased. It seems to me torque is what shreds belts, not horsepower.
The short, sweet answer is no- you will NOT need to upgrade your CVT with a governor-ectomy. With these engines, torque peaks around 2500 rpm, and then starts to drop off. Therefore, nothing changes as far as the CVT is concerned.
As for answering your question, perhaps you'd better ask it better. In your question, you compared a heavily modified small block to a stock big block. In fact, I did answer your question, by explaining CVT power and sizing criteria.
Torque shredding belts? Of course. Torque is a real, tangible, measureable force. HP is a steak sauce. It doesn't mean much in the real world. While we're at it- torque itself doesn't do anything- it's torque over load. A seriously huge engine with a very minimal load won't kill a CVT belt any faster than a small engine with a large load.
That about cover it for you?
Traviss1990
I'm learning more and more lol. So, what you are saying is that if a TC is rated for a 6.5 hp @ 3600 rpm engine then it would handle say 10 hp @ 5000 rpm? As long as the amount of torque is the same? I know the power band would probably have to be shifted up with a different cam, I'm just putting numbers down for example.
The TC will not handle that sort of upgrade if it is rated for only 6.5HP
You're trying too hard. If your particular CVT is rated to 8hp, then put it on an engine that is rated 8hp or less. If the engine has had SLIGHT modification from it's factory form, it's still okay. If the engine started out as a 6.5hp and you have turned it into a fire-breathing race engine, don't use that 8hp rated CVT, because that 6.5hp is now well over 8. It's that simple. Since torque is correlated to hp, and hp numbers are widely available, use those numbers to guide you.
Traviss1990
Traviss, have you joined this group before under a different name? Perhaps Monkeys1990? I mean no disrespect, I'm just wondering.
No, I'm just trying to learn as much as i can about torque converters. I wouldn't be asking these questions if I had found the answers through the many hours of research that I've done so far. This topic hasn't been covered yet and by opening this thread I was hoping to change that.
