Hi, I'm new here and I had a question for you. I was ripping through clutches like night and day, so I opted to purchase a Torque converter, I had seen one on my friends go cart, and liked it a lot.
To start:
I've got a 6.5 HP Greyhound Harbor Freight engine.
I purchased the Torque Converter from this website.
http://gokartsusa.com/tav3034bore35chainfortecumseh5or6hp.aspx
On the specs, it was rated for 2-7 hp, perfect for my application.
5" wheels all around, slicks. Only ridden on road, around my neighborhood.
I got the torque converter about 1 1/2 weeks ago. I installed it 3 days ago because we had to reweld mounting brackets to hold the engine. I've ridden it for a total of about 3 hours. The belt is crazy worn. My friend's belt was about 7 months old, not nearly anywhere close to my belt's wear.
The cord around the edges has been ripped out, and the inside of the belt is worn like crazy.
I put the torque converter pulleys on perfectly aligned. It's an a-symmetrical system, so the belt has arrows which point towards the engine, like it's supposed to, and is. The pulleys are on correctly, but it keeps wearing the belt. I was riding it before, and upon coming to a stop, the cart shakes, and the belt gets caught in the driven pulley, halting the cart to a complete stop.
Please help me. I would like to figure this out before I purchase another belt, and put on another one and have that one get ruined also.
Thank you.
To start:
Thank you.
There is very little tolerance on this spec. If the shafts are too far apart, it might allow the belt to ride too low in the driven pulley at speed, where rivets can chew it. Look at the wear pattern in the driven pulley and see if it looks like the belt was riding too deep.
