Torque Converter issue..........
Joe-405
Enjoying New Projects
U.S.A.
So first and foremost I am NOT blaming go powersports as this was a one off deal designed by me.
But I do not have a neutral at all. If I put it on a block and start it everything works perfect. But as soon as the back tire stops it kills the engine. Isn't the belt supposed to have more play than this..........
I think when I told them I wanted this other driver it screwed it all up. Does anybody know if the 40 series is smaller or different than the 44 magnum series driver ? I can get belts from my work and order one to have it by next weekend for my car show I'm going to but inwanna make sure. I looked at the 44 and 40 instructions but they don't really say anything.
P.s. It didn't stop me from getting the first test ride in tho !!! Lol
Joe-405
U.S.A.
Just found the differences. It's 11/64 bigger in diameter than the regular one they make it with. I'm assuming have enough for it not to work correct ? The next belt up is almost a 1" longer and I bet it's too much.
Edit.... Thanks for the help but I think I got it figured out. I will just add another spacer between the driven to make it wider. Then I can keep my 2 belts I already have. And when they stretch I just pull the spacer back out. Whatcha guys think ???
It's circled in the picture
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
11/64s bigger is only 1/20th of an inch more in circumference. I am assuming, Should not make that big a difference.
KartFab
Dallas, TX
Besides looking at center to center you need to check the spacing of the belt from the drive unit. With the 30 series you need at least 1/8" gap? Not sure about 40 series.
Less torque on startup, but that's not really a big deal. If your belt is too short, it could ride up against the crush washers and shred the belt a bit, or it could actually damage the torque converter itself from the stress.
Can't you just re-drill a few holes on the plate to match the center to center that you need?
Joe-405
U.S.A.
I redrilled the holes. its far enough up i had to clearance the crank. But it works a little bit now might try moving it back to normal and trying the next size up belt
