Torque Converter, I'm very confused!
MancoGX390
Just tinkering...
Devon, England
when my GX390 is mounted to my kart i have it running through a comet 40 series torque converter. My smaller kart has a GX160 and a 30 series torque converter. Now the thing that is odd to me is that the GX160 powered kart goes faster. I'm pretty sure this leads into gear ratios. When im driving the GX160 powered kart as im going down the road full throttle i can hear it changing the gear ratios and the top speed gets faster, my GX390 powered kart with the 40 series never seemed to do that and therefor dosen't go as fast? I'm very confused! Weather the GX390 is so powerful it just runs out of ratios to pull through i don't know! Would be very greatful if someone could help me out!
Half-breeder
"Edit" button removed
Have you even bothered to count the teeth? Have you bothered to study the calculator provided by the site? Is The 30 series a TAV2? How heavy are the karts in question, wheel size, kart weight?
When im driving the GX160 powered kart as im going down the road full throttle i can hear it changing the gear ratios and the top speed gets faster...
Umm you got REALLY good hearing if you can 'hear' it changing gear ratios... my guess is your just hearing the motor rpms raise.
Possibly may have something to do w/ the weight difference and the gearing as well...
MancoGX390
Just tinkering...
Devon, England
Well the GX390 is a Manco Dingo Which is lighter than the Wasp go kart that the GX160 is bolted to, the Wasp runs on 18" tires and the Manco runs on 22". Out of the two the Wasp is the heavier kart. As far as i know it is just a standard comet 30 series torque converter on the Wasp, i don't think its a TAV2. With the Wasp you can hear it changing the gear ratios because the engine will start off on high revs and as you speed away the engines rpm will dip and peak just like a automatic transmission. The Wasp axle sprocket is 64 teeth, i think its a bike sprocket the guy put a bigger one on before i bought it and the jackshaft is a 9 tooth i think, could be a 10. The Dingo's axle sprocket is a 54 tooth with a 10 tooth jackshaft sprocket.
Half-breeder
Oh... 'that' sound... no that's the sound of your belt slipping at first... then heating up and becoming sticky, grabbing traction on the pulley and finally catching up... then reaching top speed. (Not all belts will squeal when slipping).
5.4:1 ratio on 22"... there's your problem(>.<)
7.1:1 or 6.4:1 ratio on 18"... (not bad)
'Sometimes' (for a TC) you'll need to go higher in ratio to attain 'top' speed(even though dropping ratio=higher speed), the cause is, motor just wont spin it(not enough HP on the topend of the rpm scale... a cam helps that and so does a bigger bore carb... but that isnt what your asking ... (in 'this' thread).
MancoGX390
Just tinkering...
Devon, England
So would you suggest a 9 tooth jackshaft to a 54 tooth axle sprocket instead of a 10 tooth jack because that was the original setup and that gives a gear ratio of 6.000 or i could keep the 10 tooth jackshaft and step up to a 60 tooth axle sprocket, what would you do? Or another option is to set it up how the GX160 is set up with a 9 tooth jackshaft and a 64 tooth axle sprocket and I should then get roughly the same top speed but not sacrificing too much acceleration
Found this handy page that is helping me understand pairing sprockets a little easier!
http://www.gokartsupply.com/ratios.htm
Half-breeder
Honestly Dingo's are not my cup of tea, so I know lil bout em other than the obvious things. IMO id put a 6:1 ratio w/ as small a gear on the axle as possible(for ground clearance), and get a set of 20" wheels. If you have a TAV2 youll be running bout 40mph... if your just runnin a 30 series youll be top speed of bout 35... ish.
Someone else may have their 2 cent to input... Lord knows Im the last person to rely on bout questions... Ive only started the kart thing for bout 1.5 yrs now... and seem to only be able to troubleshoot issues w/ cutoff switches and their wires... yet... I seem to have made a kart that does what alotta folks strive for in their karts... however, Ive been told I probably shouldnt do over half the things that I have done to it.
MancoGX390
Just tinkering...
Devon, England
Well thank you! I think I'll try the 9 with the 54 again as that gives me the closest ratio to 6:1, coupled with my 40 series torque converter and ill try throwing the 18 inch wheels from my Wasp on there I should be ok and see how it goes! Thanks again!
