torque converter help
Mattiew7
south carolina
Im new to the diy gokart forum! Im needing help on deciding what torque converter to use. I have a 5hp fun power briggs on a streaker frame. Im currently upgrading the engine. Ive tore the motor completely down removed governer, getting it bored +.010, I think its called milling my exhaust port and intake port, dyno cam 94ss, billet rod, billet lifters. Also upgraded the carb its off of a raptor engine. Not sure how much horsepower ill be pushing with those upgrades so not sure on which torque converter to install cause i know my 30 series that is currently on it want handle that motor now.
Help needed please!!!!
Mattiew7
south carolina
Thanks landuse! I've been looking at the 40 series and 44series torque converters I need the driver to fit a 3/4" shaft and the driven to fit a 5/8" shaft any suggestions on where to find this set up?
I spent a fair amount of time digging and could not get a conclusive answer. While the series is "compatible" I could not find an indication of exact belt selection.
