r97
Measure twice cut once
Hello,
I have a GTC TC2, which is a clone of the comet TAV2, 30 series. unfortunately i do not own a COMET 30 series (of course they are for sale again
) so i cannot compare between the two.
Anyhow, i have noticed my torque converter gets HOT, i sure wouldn't enjoy holding on to it for a second or two, and that's only after like 20min!
i'm geared for about 38 MPH @ 4000 rpm, with a 6hp engine, in a one seat kart, on the street, going up some minor hills, flooring it most of the way. maybe, its just me, but I don't think i'm asking too much.
if it helps i can also get pictures of the TC, assembled, and/or disassembled as much as you want.
one thing i have noticed is that even uphill it is in the overdrive ratio. i would say that either shows 1) the system is not at all being stressed, but then why does it get so hot? 2) the system is not functioning correctly, maybe bad springs? i have considered buying comet springs, not sure if that would do anything.
also, just recently the speed has dropped off considerably unless i'm going down hill WOT, but up hill and flat ground are wayyyy slower than usual.
if your curious, the belt should be correct (unless GTC gives the wrong belts to you) and is installed correctly. it has lost 1/16" from the top width (that may have something to do with speed, but not the heat problem). if 1/16" is a lot to loose from the belt, this thing eats belts, can't have more than 4-5 hours on it!
soooo, to my questions:
- those of you with comet TC's, does your TC get too hot to touch?
-what would cause a TC to get very hot?
maybe i'm just being stupid, and all TC's get hot just from the belt moving around, but if its not normal i would like to fix it.
) so i cannot compare between the two.Anyhow, i have noticed my torque converter gets HOT, i sure wouldn't enjoy holding on to it for a second or two, and that's only after like 20min!
