well fairly obvious fault I'm afraid..
the outer bell came loose (someone hasn't tightened the bolt correctly
and the rest is physics...
Now, nothing too bad happened to the TC obsviously.
First remove the garter springs from the weight-pack (that now oval thingamabob)
make sure the garter springs both snap back straight..
they MUST NOT BE longer than 7 7/8";
if they are they're now worn out and need to be replaced..
(the color you want to order is blue in case the shop sells different ones! blue is the std spring)
Now pull apart the weights so you have two identical parts.. make sure the one guide pin is not bent.
if it is you need a new weights pack (with springs ~20 bucks)
but as long as shipping takes, just put them back together properly (thread in the guides into the corresponding holes)
reattach the garter springs if they're in working order (straight and no longer than 7 7/8")
And make sure the hooks are on opposite sides and dead center between the seams.
clean everythign up, apply a light coat of dry lube on the inside of the inside faces
of the clutch (NOT the sheaves, just where the weights ride inside the closed bell)
close everything up, use a drop of thread lock to secure the bolt and tighten it to specs.
and everything will be nice and functional again
