Toycrusher
There's been plenty of questions about this (and there's probably been better explanations than this...)
A Torque Converter consists of two components, a Driver clutch, and a Driven clutch. Each component is independent, but they only function as a pair. A Torque Converter is not a "smart" component, it is very much "dumb". Each clutch sees nothing other than it's own rpm via centrifugal forces.
So how does a "dumb" Torque converter work?
We'll start with the driver clutch. It is nothing more than a variable diameter pulley. It starts as a small diameter pulley, and finishes large. At idle speed, the pulley is so small that it does not contact the drive belt, and therefore, there is no transfer of motion from the engine to the wheels.
As engine rpm rises, the driver clutch begins spinning and centrifugal forces begin to act on a combination of weights and springs. At a calibrated rpm (calibration changed via springs and weights) the pulley begins to grow until it contacts the drive belt. At that point the belt transfers power to the driven clutch and kart motion begins.
At a set rate, the driver clutch diameter (effective diameter, not physical diamter) continues to grow from the engagement point (basic off-the shelf, around 2300 rpm) until reaching it's max diameter at a set rpm (3200 ish standard). As the driver clutch increases it's effective diameter, it spins the driven clutch faster and faster, at a much quicker rate than the increase of engine rpms.
So why do we need a driven clutch? Why not put the other end of the belt on the axle? Because as the driver clutch grows in size, the tension on the belt increases and without something to give on the other end, the belt would get tight and either prevent the driver clutch from growing larger, or break.
Now the driven clutch. How does it work? It's like the driver, but in reverse, using ramps and springs to allow for a decrease in effective diameter as it's own rpm increases. The faster it's spinning, the smaller diameter it becomes, exponentially increasing the output sprocket speed, moving your kart faster and faster with no significant increase in engine rpm.
So why do we need the driver clutch? Because without one, as the driven clutch gains speed, it becomes smaller, the belt would lose tensions, and your forward progress would cease.
The driver and driven clutches need to be tuned for each other, with regards to kart load, horsepower, gearing, wheels, etc for them to function properly. In a properly tuned setup, power flow is as follows:
Driver pushes on the gas pedal lightly, engine rpm rises to engagement point (2300 rpm ish) and driver clutch begins to engage belt, spinning the driven clutch. Kart begins accelerating and gains speed to 5 mph for our example. If the driver and driven clutches made no further changes, as the engine is accelerated from 2500 rpm to it's governed 3500 rpm limit, a 30% increase in speed, the kart would increase at that same rate from 5 mph to about 7 mph. Hardly exciting.
However, as the driver lays into the gas, the engine begins building horsepower, rpm increases which increases the effective diameter of the driver clutch, spinning the driven clutch faster and resulting in a corresponding decrease in effective diameter there. Our engine rpm is now 2900 rpm, an increase of only 14%, but our karts speed is now 15 mph, a 300% increase in speed. How? by means of the changing driver-to-driven pulley ratios.
Driver now goes full throttle, engine pulls towards it's 3500 rpm governed limit, the driver clutch grows to it's max size and the driven shrinks to it's smallest diameter. Another 17% increase in engine rpm but kart speed grows 60% up to 35 mph.
Pretty cool huh? But what happens when you come upon an incline? Does the engine bog and die? Nope. As the load on the kart increases, the engine hp can't maintain that same kart speed. The kart slows to 25 mph, the driven clutch slows at the same rate as the kart and the reduced centrifugal force causes it to begin growing in diameter, reducing the load on the motor. Simultaneously, the engine rpms had been dropping due to the increased load, this reduction in centrifugal force on the driver clutch caused it to begin reducing it's effective diameter, also lessening the strain on the engine.
This near instant "load compensation" of the Torque converter keeps the motor in it's power band. This is what allows smaller horsepower engines to perform like much larger engines.
So which torque converter do I get? Application, Application, Application...
The converter must be matched to the engine powerband. If you build a 9000 rpm jr dragster engine, but use a converter that engages at 2300 rpm, well below the powerband, the motor will never get moving. Likewise, if you use a motor governed at 3500 rpm but have a racing converter that engages at 4000, it will never reach the engagement point and you'll be doing nothing but free revving your engine.
Hope this helps some
