Torque converter driven clutch?
Greyhair
NE Oregon
Question on using a driven clutch from a torque converter as the pulley on a vertical shaft engine. Would this mean that the clutch would be the driven instead of making a clutch for a vertical shaft to the transaxle? If so what belt would you use the torque converter belt or the normal belt motor to transaxle? Have never heard of this as a option when setting up a vertical shaft. This was done on a racing mower. So you would let off of the gas to shift? I hope I'm making sense! Greyhair
