torque converter/ clutch help on a 16hp clone
pgreen491
Hi everyone I'm new to the forum and trying to get some information right I keep getting different answers from different shops. I have a old dingo with a 16hp clone with the govenor removed , the rear tires are 15 inches and it has a 54 tooth sprocket on a live axle, my question is I have a gtc tc2 torque converter 1004 that is rated for up to 13hp and I was told I could use it without smoking it if the gearing is right, can someone tell me if this is correct and if so whats a good gear setup to use, Im not going to offroad the kart and would be happy with 35 mph or so. If I cant use that I was going to get a 10 tooth enforcer clutch with the 54 tooth or what ever rear sprocket you guys think will work best. thank you for your help.
dave1701
Good for 100,000 Miles
MICHIGAN
I think you need the right size torque converter for your engine. If my memory is correct, those GTCs don't even work well with 13hp.
