karl
Done got a problem. Too much torque. At like below 20mph if you hit the gas
the belt climbs up the driver and slips back down and just aint having it.
After its moving a bit, the belt grabs fine and it moves stupid scary quick like.
It's not gear ratio, the used the same clutch , sprockets, tires, ect with
a gx270 and it worked fine. The 40 series just does not appreciate the
extra 11ft/lbs of the 459cc.
Any ideas? the 44 magnum driver does not run inboard, and yes it
has a genuine comet belt. I took apart the driver and cleaned it up, and dry lubed it.
