porsche930dude
I looked at instuctions and it didnt really say. I have a comet 20 series. When assembling the rear driver unit you pick your setting 1 2 or 3. do you have to tention the spring in either direction when putting the hub on? When you slide it straight on the scrubbers hit on the high spots. #1 ends up on the leading edge #2 ends up right in the middle of the scrubbers and #3 ens up on the trailing edge. I see pictures of it either way so which is it. i tried it both ways the leading edge workd ok but as soon as you let off the gas it down shifts hard and definatly didnt feel right. when on the trailing edge it wouldnt upshift. Could it be just because its fresh greese and its -10 degrees out so it wouldnt slide good? This is on a 5hp briggs . Thanks
leading edge
or trailing edge
leading edge
or trailing edge
