Torque Converter Advice Needed for EX27 Engine
JoesEdge
Downey, CA
Okay, so I'm putting together another go-kart for my son. This one is a bit bigger than his previous cart.
I bought a Subaru EX27 engine on Craigslist. It's rather at 9 HP and has a 1" crank.
From the threads that I have read on this site, I have come to the conclusion that I need a 40 series Comet torque converter.
I have the following questions:
  1. Is this the right torque converter for my application?
  2. Where can I find this torque converter and can it be bought as a kit?
  3. Is there a mounting back-plate like the smaller series torque converters?
  4. If there is no mounting plate, then what's the distance between the cetner of the driver and driven clutches?
  5. Can anyone point me to build threads that go into detail how they set up a 40 series torque converter?
There's probably tons more questions. But this seems very very expensive route to go. Is it the right route to go?
Joey
the-cyborg
Spring, Texas
You could probably get away with a 30 series, but I personally
install a 40 series on 8hp and up. less than 8hp 20 or 30 series will be fine.
r97
Measure twice cut once
Massachusetts, USA
1. yes
2. e-mail northern tool, BMI karts, and mfgsupply, they might have a driver and driven, maybe in a kit form maybe not. beware of comet knock-offs. check ebay and cl regularly.
3. no back plate, you will need to install a 3/4" jack shaft with 3 mounted bearings. big sections of tube with a built in jack shaft that the engine bolts on top of are available separately.
4. center to center will be determined by what size belt you use.
5. none that i know of, but search the forum you may find something.
EX27 with a 40 series is going to be insanely powerful, and potentially very fast, you could probably spin the tires and hit 40mph easy. my EX17, 6hp go kart with a 30 series gets to about 35mph and gets stuck in gravel driveways because the tire spins so much.
what engine and clutch did you sons last kart have? where do you drive it? describe the size of the kart (# of seats, roll cage, etc). then describe the new kart with the same criteria.
JoesEdge
Downey, CA
1. yes
Thanks for the advice. I'll give those company's a call. Maybe they can do a "kit" deal or something especially if I'm buying all the parts all together.
Can you explain the jack shaft part a bit better. I have sort of a mental picture, but I'm not sure why it would need 3 bearings.
I imagined that the jackshaft would need at least 2 bearings (one on both sides), the driven clutch, and a sprocket.
I'd really some pictures of this type of setup so I can better visualize it. If you have any, or know of any links that would be great.
I'm hoping this engine would be able to move my 240 lb fat butt well. LOL
The other go-kart that my son has a Tecumseh HS50 engine. I guess it's rated at 5 HP. It has a Max Torque clutch that I got at a lawn mower shop. I'm not too crazy about the clutch, but t works.
He usually drives it off-road like in grass and we even taken it to the desert once. It gets up and goes even with me in it.
I'll post pictures of both this weekend.
Joey
r97
Massachusetts, USA
well here is the mounting plate thing i was talking about,
http://www.diygokarts.com/vb/showthread.php?t=9686&highlight=comet
as for a "home brew" jack shaft, i think two bearings (one on each side w/ sprocket and driven in the middle) on a 3/4" shaft would work nicely. 3 bearings would be (bearing, driven, bearing, sprocket, bearing. or bearing, driven, bearing, mounting box, bearing, mounting box, sprocket.) hopefully that makes sense, but to sum things up, the best thing to do is to just make sure both the bearing, and the sprocket are supported by a bearing on both sides.
http://www.diygokarts.com/vb/showthread.php?t=9052&highlight=series
this engine w/ a tc is going to be leaps and bounds ahead of a 5hp w/ what i will guess is a cent clutch.
r_chez_08
Should be in the shop...
Cornwall, UK
You could use a 30 series tav2 if you wanted. They are only reccomended for 8hp, but the worst would be a few new belts. They are cheaper and have a backplate.
r97
Massachusetts, USA
i know its not the 30 series, but a member named metalthrashinman has experience using a GTC TC2 (30 series copy) on an EX27 with horrible results. i have also read many times that the Subaru EX27 is underrated.
JoesEdge
Downey, CA
Yeah, seems like that 40 series will cost more more than the rest of the kart. That's the part that kills me. Can I afford it? Yes. But do I want to spend the money on that? That's iffy.
the-cyborg
Spring, Texas
Think of it like this at $20-30 bucks a pop on belts and replacing disk and springs on a 30 series due to strain or get a 40 series that can more than handle the stress with with little to no maintenance. Either you pay on the frontend or pay for repairs and belts on the backend.
Btw you only need 2 bearings and 2 lock collars more than that is really overkill .
