Fast_Chicken
- Messages
- 6
- Reaction score
- 0
Hello,
I am working on a frankensteined Kenbar Streaker kart. The rig is equipped with a Honda GX120 motor mounted on a Peerless 855/860 transaxle.
For more background info feel free to see my previous post here:
http://www.diygokarts.com/vb/showthread.php?t=14827
The GX120 has a shaft diameter of 3/4" (Is this called a Jackshaft?)
The input shaft diameter on the transaxle is 3/4" as well.
The transaxle is comonly used on ride on seed spreaders and then also medium duty tractor lawn work equipment. It appears to be a good quality transaxle.
According to Peerless this transaxle works really well with a Comet 20,30 or 40 series Torque Converters. So my next step is to pick out the right converter. And this is where I could use some help.
The engine is only rated for 4 hp so I am thinking on sticking with a 20 (maybe a 30) series to save a few bucks.
Some other specs:
The center to center distance of the shaft is roughly 9"
I was looking here http://www.gokartsupply.com/tavapp.htm , for example, and I am unsure of what I need. Is this a complete kit? There are other terms I am unfamiliar with; for example it says that the "Kit is For #40,41 or 420 Chain, 10 Tooth Sprocket" How does that apply in my case. My kart doesn't have a chain but it goes straight to the transaxle? Info is greatly appreciated.
Thank you for reading.
Some other specs:
