Torq-a-Verter won’t Disengage at Idle
anickode
S.E. Michigan
Make sure the belt is on the right way around.
Check all shaft keys
Make sure your brake and/or bearings aren't bound up
What is your gear ratio and tire diameter?
Brianator
Gettin' er done!
Barrie, Ontario, Canada
Lol. I have a off brand too and it's been working better than I anticipated considering it's on a Champion 6.5hp in a (full sized 2wd) ATV with 19 inch tires, a (less than ideal) 5.4:1 gear ratio AND the driven spring is still in the middle hole. One thing I did notice is that my belt needed a break in period before it started gripping well. Before I get into the mechanics and adjustments of the torque converter let's start with the basics...
Even though the torque converter came as a unit with a backplate did you space the driver on the motor so the inner sheaves flat discs are in great alignment with each other? If not start there.
Does the cart roll freely WITH the weight of the driver? If not some things to consider are the brake(s) dragging, low tire pressure, worn bearings, drive chain too tight or ?? All good? Moving along...
Find out what your gearing and final drive ratios are by using the KartCalculator live app at app.kartcalc.net. In the settings menu change the units to what you prefer, in the "Quick Calc" menu enter your data and it will spit out a bunch of info. For the tire measurement you want the outside diameter of the tire by measuring from the floor to the top of the tread, forget what the tire is labeled as and you only need to measure one rear tire. Report back and we'll keep moving ahead.
I see you have a Honda GX200, that motor should have plenty of get up and go if it's in good working condition, make sure you're getting full throttle at the motor when you're using the gas pedal. It will be a little restricted with the stock air cleaner and exhaust but it shouldn't make it suffer TOO much, not like a bad gear ratio will. Is the governor installed and functional? If it is don't attempt to bypass it as that's a recipe for disaster but there is a long screw with a spring on it that limits the travel of the throttle and therefore the max rpms the motor can turn, you can back out the screw to increase the max rpms safely (to approx 4300) which in itself should help alot and heres why :
The driver clutch stock setup doesnt start to engage until roughly 2300rpm which leaves only 1300ish rpms of (not so much) fun.... increase that to 4300 and now you have another 700rpm of belt grabbing centrifugal force to help. Last but not least if you change the hole in which the drivens spring is sitting in so the spring has more tension it will delay the "shifting" process of the driven giving you more torque for a longer period which helps with acceleration and inclines.
That's all I got for now but as a quick recap:
- check pulley alignment
- check to make sure the cart rolls freely
- use KartCalculator to find potential issues
- make sure the motor is up to snuff
* anickode had a couple great suggestions also which I somehow completely missed until after the fact*
To make sure the torque converter is working as intended and that the motor will wind out get the rear tires off the ground and give it heck, I dont want to sound like the safety police here but please do it in a safe manner so no person nor animal gets hurt if things go awry. Class dismissed!
MancoAddict
Sycamore, IL
It’s working in amazing fashion! The fix wasn’t one exact thing but rather a multitude of small forces acting together. Fortunately, it wasn’t as simple as the belt being on backwards or it being bound up at a bearing or brake rotor. I’d feel even more inept than I already do lol. Rather it was the alignment being off by a few mills due to the keyed washer being located in the wrong position. Moreover, the throttle cable had loosen some not granting the engine it maximum rpm.
It all came together with Brianator’s explanation (which I was ignorant to the fact) of rpm engagement of unit itself. My motor was barely providing that rpm due to the throttle cable being partially engaged. My TAV2 did not come with a manual or install instruction in the box, I might have been able to figure this out on my own.
Anyway, the combination of alignment corrections, throttle cable adjustment along with removal of the throttle restrictor screw, opened her up beautifully. Lastly, I would contend as well that Brianator had a good point (once again) that the belt may have had a break in period.
Anickode and Brianator, thanks again for all your help through this process.
Finally for posterity, my old unit that was engaged at idle was due to mismatched Comet Torq-a-verter parts on a pretty worn unit. The belt was also incorrect but the real problem was the driver pulley pinched the belt because the outer cover of the driver was incorrect and I did not have the correct fastener for the drive unit for the Comet unit.
