Too much torque
Grimace
Mr. Furious
Plus too much bite on the tires =
Busted 3/4 inch jackshaft. Time to make a 3rd bearing support.
groan.
Grimace
Mr. Furious
Oh yeah, all of the dents and dings are new. I had the throttle on the wood when it broke.
Funny, this reminds me of drag racing. Build, race, break, build again better.
augidog
when you rebuild, you can consider adjusting the driven pulley to be a bit softer.
Grimace
Mr. Furious
Clutch is working fine. Goes from low gear to high and back to low just fine. Would recommend it to anyone. Just need a third bearing support outside of the drive sprocket off of the jackshaft to take the torsional load.
klicky96
Sandusky, Ohio
With my jackshaft, I kinda over achieved and used a 1" axle i had laying around. Kinda too much but its not gonna break. With another bearing, it will give you support, yes, but it might still break in the future. IMO, I would get some steel tubing, and run a sleeve over your jackshaft to keep it from flexing. A better thing to use is a shaft stiffener. they work great, just slide them in between your sprockets and bearing and tighten them down. Both of these ideas will keep your shaft from flexing/twisting.
