Thanks guys, that's pretty much what I was thinking...
I recently purchased a used mower & two things concern me:
- steering is extremely light; my old mowers steering is much heavier, indicating something isn't set correctly &
- the factory tie rod isn't long enough to allow for more than a degree or two of toe in but has way too much toe out...
With the wheels set close to parallel (just eyeballing, I haven't measured yet) & the toe rod disconnected at one end & the rose joints centered on the threads, there's 20mm between the knuckle bolt & the rose joint centres... I'm considering stretching the tie rod...
This is after I had to repair the steering mechanism; here's what the gears looked like...
...&, of course, dumb a$$ here didn't take "after" pics; let's just say there was some welding & a LOT of filing/grinding involved but, at least I won't have to worry about that ever again...
