To be a Faster Warrior
MoWarrior
Frost, TX
Hey Everyone,
Been reading DIY for the past couple of days and really enjoyed it.
Am currently seeking tips on how to make my new Baja Warrior a faster and sleeker machine.
http://www.diygokarts.com/vb/attachment.php?attachmentid=51685&d=1409931925
Also have two mowers (one Poulan, one John Deere) which I eventually want to modify for racing, but those will come later!
http://www.diygokarts.com/vb/attachment.php?attachmentid=51686&d=1409932431
http://www.diygokarts.com/vb/attachment.php?attachmentid=51687&d=1409932431
All suggestions for the Warrior will be welcomed as it's my daily driver here on the ranch!
firemanjim
Just kartin' around....
Houston Texas
:welcome2: fellow Texan! This is an easy one..... Mod your engine a little. Then change your gear ratio to a little bit taller ratio.... (if you have a 60 tooth rear sprocket, you can drop to a 52....... ) You don't want to change it much, because you will lose low end torque.....
MoWarrior
Frost, TX
Yeah, right now it's totally stock, as it came from the factory. Have a very limited budget, so will ave to do things in stages. So what would be the least expensive way to start?
KartFab
Dallas, TX
Save up your money, then buy this. Don't do anything else till you do it right the first time.
http://www.ebay.com/itm/Torque-Conv...604?pt=LH_DefaultDomain_0&hash=item4d19e28db4
If you wanna go cheap to get more speed you will end up burning up your clutch, not being able to climb hills, or ruining the longevity of your engine.
If you want to know how to install it here is this:
https://www.youtube.com/watch?v=82AirkKFyo0
The guy in the video is a little bit of a dweeb, but he does a great job of showing how to do it step by step.
