Barefooter
- Messages
- 3
- Reaction score
- 0
I am new to go karts and purchased a brand new 2 seater go kart( with 300lb weight limit) what I thought was a nice one for my 7 and 6 yr old boys. Unfortunately I have learned the hard way about internal clutches with this particular set up. I have a Polaris Turbo S that I rock crawl with and while I know my boys cannot follow me I want to be able to take them out on easy trails. They are bored riding with me and I don't blame them. I drove the kart on the pavement( I weight 240lbs) and could tell right after I bought it something was wrong with the clutch. We took it out with the boys and within 15 mins of a gravel parking lot it burned up the clutch. I paid for it to be replaced and changed the oil in the motor. My oldest weights roughly 55lbs and has burned the clutch up while riding in a relatively flat field within 45 mins of driving. He is very coachable and kept his momentum while climbing what tiny slopes where in the field. Returning the go kart is not an option as I have tried to make that work. I don't feel right about selling it to someone else either for them to have the same problem. I figured I have a few options and was looking for advice or a direction to go to so I can research which option would be best for me. I am not sure how much information you would need to help me but I will give what I know.
13 tooth sprocket on engine
38 tooth sprocket on axle
18x9 tires
Options:
1. Change sprockets to lower gear ratio( I was told it would be difficult to source correct sprockets with Chinese build).
2.Install CVT on current engine( Not sure if this is possible but this would be my preferred option)
3.Replace engine with 150cc engine with CVT( New swing arm needed ?) What is a 125cc engine worth with less than 2 hrs on it?
4. External gear box
18x9 tires
Options:
Because of that engine your in a tough spot. It is probably internally geared down 2:1 in addition to the external gearing on the sprockets with about another 2:1 with the sprockets. Not good!
