Kartin’ kid
I have a set of Unilli 12x9 slicks mounted on 10x6 wheels and I was wondering what the correct psi is for a setup like that. I’ll be driving exclusively on asphalt and concrete if it matters
That is standard practice, no matter the manufacturer or intended design use, but I have seen a few tires here and there where the only option was guessing and loading to squat checkMost tires have the proper inflation pressure, right on the side of the tire (the Unilli's that I had on my Excalibur kart did)
Googled it, found nothing. On almost every tire it does say on the side but you’ll notice that it says MAX INFLATION. this is not what you want to inflate your tire too, simply the maximum amount of pressure before you are in danger. Same rule for full sized car tires. Never permanently inflate one to max inflation. As for checking where I bought them, I thought I did but I’ll look againMost tires have the proper inflation pressure, right on the side of the tire (the Unilli's that I had on my Excalibur kart did)
...or check on the specs with the place from where you bought them
...or even just Google tire inflation pressure for Unilli 12" x 9" slicks
^Basically dust the ground and see what sticks where on the tire.With racing slicks the lower and squishier the better usually. What you want to do is take a piece of blackboard or sidewalk chalk and air down until you get wear across the tread of the tire. Nice even wear. Start at around 20 lbs and go up or down from there. The little holes in the slicks are wear indicators.
