Tire Help
YungVick
Hey Whats Up Dyi First I Wanna Thank Everybody Dat Helped Out On My Last Post...Appricate It!! But Anyway I Was Recently At A Garage Sell And I Found 3 "4.10/3.50-4" Tires I Really Didnt Want Da Tires All I Wanted Was The Hubs And Intertubes Which Where In Great Condtion..Im Really Kinda Confuse Bcus I Want Slicks On My Kart But I Really Dnt Know Would Da Hub Fit For The Tires I Wanna Order On Line Which Are The Same Size 4.0/3.50-4? Here A Couple Of Pics!!
Hers Da Old Tires 4.10/3.50-4
Hub With 72 Teeth Sprockt
And Heres The Hub That The 4.10/3.50-4 Tire Was On
YungVick
Nope Actucally I Use A Piece Of Painters Tape To Cover It Up I Just Toook It Off For Da Pic When Its Dry Ima Spray Da Bearings With wd40
I realize nobody's got perfect spelling or grammar. Nor do we really care that much. But I gotta be honest with you- If I have to try that hard to read a post, I'm not all that inclined to see it through and answer it. So please- Put forth some effort to make your post intelligible, and we will put forth some effort to help out...
Kenny_McCormic
Kartless....
Michigan Troll
Well why didn't you say that "Insted of Talkin liek dis". Basically you have a tire for a 4" rim around 3-4" wide in an application calling for a ~11" tall tire(3.50+3.50+4=11) ignore the 4.10 in 4.10 tires, so anything roughly 11" tall for a 4" rim around 3-4" wide will work, you might be able to go wider, or it might rub on something. You can buy slicks in that size here http://www.gokartsupply.com/tires.htm
YungVick
Okay Thanks I Understand What You All Are Talking About Grammer Im Young And Us Young People Like To Make Things Quick So I Applogize For The Grammer Thanks Alot
r97
Measure twice cut once
Massachusetts, USA
of course your yung your names yung vick, lol, and yea.. i dont like spelling and all that stuff but people give up if they cant "reed da stoff liek dat",lol
redsox985
PA
Only the first word, proper names, months, days, etc. need to be capitalized, not every word. If you have the ability to work somewhat on a go kart, you are old enough to have a few years of schooling and they usually teach that stuff by like 7 years old.
YungVick
iight man **** leave it alone if you cant help out or read what I type I appricate if you not comment you can keep the negativity to your self im on here for help not to get critisize about the way i type...
fowler
Bullsbrook West Aus
tip if u dont like puntuation start a new line for each sentence or each new topic
also use grease on the bearings
they will thank u later on by continuing to work
