Tire help
portedmetal
Outside of Lafayette, LA
I currently have some 15x5.00-16NHS on the kart right now. I need to know what each of these numbers mean and a good website/store to get these tires, I don't mind if they are a little bit bigger but do not want to go smaller. I also don't want to change the rims either. I
klicky96
Sandusky, Ohio
Tires are goin on split rims. I see no need to change rims since they are fine. It's what was on the kart before. Is it possible to not use tubes with split rims?
You don't have to use a tube with a split rim, you can put the tires on the bead. You may have to buy a high modulus sealer, like caulking for bathrooms or something, but yes, you can put a tire on the bead with a split-rim.
Klicky, you REALLY gotta explain yourself. Whaddya mean "put it on the bead"? As opposed to what? I've been mounting my own tires for years and I haven't a clue what you're talking about.
And no- I wouldn't go using bathroom caulk anywhere near a tire. Right tool for the right job. Babzog, it's like this- there are two kinds of split rim. One, is just two steel halves that clamp together with bolts. A tube is required for these rims. The other is a tubeless split rim- this is easily identified by a large o-ring or gasket sitting in a groove between the halves. This does not require a tube, but I still suggest it, unless the rims and O-rings are in excellent condition.
And- there should be no problem using a 15x6.00-6 tube in a 15x5.00-6 tire (assuming I read that right.)
klicky96
Sandusky, Ohio
Like a car tire, the tires can be put on the bead. Meaning, they fit onto the rim without a tube. Also, yes, there are two kinds of split-rims, I run both without tubes. Using caulking as the gasket seals it great. Also, there is more than just 1 type of caulking. Caulking is just a rubber-type sealant.
Umm- tire bead is PART of the tire- and if you're describing the rim lip, well- it ALWAYS sits there, whether a tube is present or not.
And as a professional tradesman, I am quite aware of the multitude of caulks and sealants available. Not saying it "won't" work, just don't suggest it for a variety of reasons.
Sorry Babzog, forgot tire sizing- In your own example, 15x6.00-6, the first number (15) is the nominal tire diameter in inches. Second number (6.00) is the nominal section width, also in inches. Section width refers to the overall width of the tire, as measured sidewall-to-sidewall at it's widest point. The third number (in this case, also 6) is the rim diameter.
babzog
Thanks toystory, makes it all clear now! :cheers2:
