crazykart
Crazy member
http://www.gopowersports.com/40-series-torque-converter-kit-bolt-on/#aid=2973
Mention your a diygk member and get 10% off
Thanks Crazykart,
Budget is not big, but not so tight not to get the correct parts. I just plan for it a few weeks out. I did noticed only a few
40 "complete kits" vs 30. Most of the parts for to 40 were in
non-kits, I will need to search some more.
I made some great progression on the frame this week just waiting now for Friday parts to arrive from 2 vendors. So it will
start to come together and start to look like a kart vs a pile of
steel in the garage.
a build thread, even if it takes months/years is a lot more helpful to both us and yourself.a build thread, even if it takes months/years is a lot more helpful to both us and yourself.
As for your questions.
I woukd think the discount can be used either way, but to make sure you can message the member gopowersports here and ask.
I do not know of any other place that gives us discounts sadly (I wish there were more, we bring these companies large amounts of business! Lol)
You will do what you want in the end, but my opinion is that going to 14" tires in the front (which is what thise are) is backtracking.
Why put 14" tires up front and only have 6-7" of ground clearence especially when you're putting 18" tires in the back FOR the ground clearence??
Go with the same size all around. Iiwm I woukd nit go any smaller than 18" tires for the offroading you will be doing. Any smaller and you're cheating yourself.
You can get 8" rims that will fit that 3/4" spindle, albeit the ones I've found are a bit expensive: https://www.bmikarts.com/mobile/8-Spinner-Aluminum-Wheel-3-wide-34-Bearing_p_3281.html. though others may know a cheaper route. Honestly though you would pay less to get an 8" 4 on 4" rim and then get a hub that has a 3/4" id bearing and 4 on 4" bolt pattern, if you can find them.
Don't cheat yourself, go the same ground clearence bith front and back. You wont do much offroading with only 6" or so of clearence...
Don't worry about questions as I do like to help when I can. Remember though that doing research yourself will help you better understand as well my friend.
