timing ?
polcat1p
how is timing bumped on a tecumseh 6hp? is there any benifits?
timing is stock, and i added a filter,exhaust, and removed the gov
oscaryu1
Shaved flywheel key.
Snappier throttle, a tad more power, ect.
Cheap mod, can do it yourself.
NJOHC
NJ
Yea I'd call David. He doesnt always respond to emails. And like everyone said, it just improves throttle response and gives you a little more throughout the rev range. You just need to be careful not to shave too much off. What your actually doing when you increase timing is making the spark plug ignite sooner. Too much timing results in pinging and then you'd need to run a higher octane fuel. But Im sure David will tell you what's safe.
