Timing on a Briggs
Clayton
Saskatchewan, Canada
I have just converted a vertical shaft Briggs to a horizontal shaft. I was watching a video about it, when the guy said something about lining up a couple dots to get the correct timing. Could anyone tell me how to do this, or even hav a pic of this done right? :huh:
karl
North east Ohio
That picture isent the exact same as your engine but you will get the idea. You need to make sure the dots line up once everytime you rotate it.
Clayton
Yeah, I opened her back up and on the crank, on one of the teeth there is a line, and on the cam there is a dot, so I linked them up. The motor still wont start! but that's because that little square shaft kinda peice on the flywheel is worn and doesn't catch when I pull the recoil! Anybody know how to fix that? I thought I might just build it up with a welder, then grind it to fit.
