timing key ?
pearl111
Baltimore, Maryland
Hello I will upgrade my predator 212 hemi with air intake gas jet exhaust header, since I took the governor out. I don't under stand and I am not sure if I need the 8* timing key. Do I need to change to an 8* key if so can someone tell me. I don't know where it goes but if I have the wright instructions I am sure I can do this as I learned to take the governor out by online instructions. If I need to can someone direct me to the website instructions. Thanks for any help. mike
No, but it might help higher RPM HP (might hurt lower RPM Torque)
A 4* or 6* key might be better? Some say that didn't notice a difference.
]I don't know where it goes
You have to take the flywheel off the crank shaft.
The crank is keyed and a woodruff key holds the flywheel in place in relation to the crankshaft while the nut is torqued. An 8* key is offset so the relation of the flywheel and crank is rotated a few degrees. This changes when the spark plug fires due to the positioning of the magnets on the flywheel. When looking at the crank shaft from the flywheel side, the key gets installed so that the flywheel is allowed to rotate a bit more in the clockwise direction.
but if I have the RIGHT instructions I am sure I can do this as I learned to take the governor out by online instructions. If I need to can someone direct me to the website instructions.
https://www.affordablegokarts.com/advance-timing-install-aluminum-flywheel.php
