Timing key
Awalker702
Sin City, Nv
Would it be beneficial to put a 4 degree timing key in a predator 212 that has been rejetted, header pipe, air filter, governor removed, and fuel pump.
depends...
advanced timing shifts your peak torque to higher rpms.
you loose a bit on low rpms and gain that in higher rpms.
it might be usefull on a ungoverned but otherwise unmodified engine
(well except for intake exhaust ;))
but I cannot think of any reason *shrugs*
As soon as you upgraded to billet conrod and flywheel and of course valve springs,
and want to hit higher rpms (6k), it's necessary to advance the timing
(that's why now all ARC billet flywheel come with 8° advanced timing if not adjustable)
You'll have to see for yourself, you will not gain much other than a slightly shifted torque curve.
