Timing Help
Martinechnology
Clovis, NM US
Hey Guys Im Trying to time my engine, so I don't know if it goes on the F mark Or T mark?, I have it set to the T Mark but the valve is hitting the piston!!:mad2::mad2::mad2:
What am I doing wrong?
A little more info would be good. 110cc doesn't tell me a thing. Is it an OHV or OHC? Did you remove the timing chain or cam at any point? Are you referring to valve timing marks somewhere?
Martinechnology
Clovis, NM US
Im Guessing OHC? Its A Dirtbike, And Yes I Removed The Timing Chain But Not The CAM, And No I "timed" it and tightened everything back up and I
spun the Fly Wheel and it gets stuck at some point.
My first move (if I were you) would be to reach for a service manual. Actually, TBH- you should have paid a bit more attention upon disassembly. You saw what it should have been, not us. That said-
GENERALLY, there will be marks on the timing chain sprockets and bright links or marks on the chain itself to indicate proper alignment.
You STILL haven't told us which engine it is. Manufacturer? Model? We cannot give solid answers with insufficient info.
