Timing for predator.
backyardbandit
I have a predator 212 hemi. I put a mod2 cam in it. Cam needs 32-34 timing. My flywheel has 28 BTDC. Will this work ? If not what size offset key do I need to get the max out off this cam ? Thanks in advance. TIM.
redflash
I've got a mod 2 and have done nada with the stock flywheel....starts and runs fine.
Da Flash
Unsure what a MOD2 is set up for, but my hemi is running a Superman .265 cam, has a PVL flywheel that is also 28 degrees. My performance guy set me up with a #6 timing advance key (1.2 degrees X 6 = 7.2 degrees), so I'm running 35.2 degrees of advance.
He also advised that "a degree or two either way won't make any important difference".
