justinlogue5_0
Can't leave it Stock!
Just thought I would share this real quick, caught me off guard. I was pulling apart a Honda 190cc Pressure washer motor to see if there was any parts I needed before scraping the no good motor. Pulled the valve cover off and it has a solid plastic cam with only ONE lobe to run both exhaust and intake valve, AND it is ran by a little rubber timing belt that goes around a gear on the crank inside the motor. Had a pin that sticks outside of the motor. When you pull that pin out the cam just falls out. That would really suck to be looking at the motor and go, "wonder what this pin does"? Pull it out and now the motor hat to be tore down and repaired,lol.
