-Timing advance key
-Billet flywheel with built in timing advance
-Have a new keyway cut in the existing flywheel
-As a last resort, simply leave the keyway out & set the timing (not recommended but, it works); be sure the flywheel nut is super tight...
Just out of interest, what is the standard timing setting? (of all things, I've never even thought to check it for myself)
EDIT: One source indicates timing is factory set at 25° BTDC
